View Full Version : bizhub 601 jam 14 in adf
mrfuser
03-16-2012, 12:32 AM
Everything looks good, but paper starts to feed and stops before going down.
Any thoughts? Shows jam 14
Kelly
JustManuals
03-16-2012, 10:40 PM
Just Manuals ~ The Internet's largest selection of manuals ~ Instant Downloads (http://www.justmanuals.com)
Paul@justmanuals.com
joaopauloooo
05-02-2018, 04:05 PM
I'm having the same problem here, did you manage to find a solution?
allan
05-03-2018, 05:15 AM
bend the cover switch on the front side up a bit...
If you hold the cover down and it feeds that is the problem.
copyman
05-03-2018, 12:20 PM
Blow off sensors (one sits down inside top cover and hard to see). Also check white/blue one way gears (feed & registration), clean pin bearings, scuff up shaft and put one way gears back on.
DSharpe
05-07-2018, 06:19 PM
If you lift up the cover on top of the adf there is a switch on the front side for the open and closed state of the door. U can try reforming that metal to make more contact or replace the switch itself.
