View Full Version : Recomanded for the Konica Minolta copier
Copyjaya
03-18-2012, 12:14 PM
Hi all ,
Actually im now using some of the canon & ricoh model's copier .
Will like to have a try on the Konica Minolta copier . :o
Any suggestion on which are the recommended models within these few years ? :o within or less than 50cpm's model .
Thanks in advance.
Copyjaya. :)
serginho_vl
03-18-2012, 09:57 PM
You can try a bizhub C353 or C451 for color and bizhub 420 or bizhub 500 for black and white.
Stay away from the C250/252 - the IU's are very weak. If you're low on cash you can take a C450 with low meter.
EarthKmTech
03-18-2012, 11:57 PM
C450 colour Iu's self destruct too, not quite as bad as c250/c252/c352 though.
colour control panel onwards regardless of model should be OK.
Copyjaya
03-23-2012, 10:38 AM
:o Thanks for advise ! :o
will study on these models !
Copyjaya
07-15-2012, 09:15 AM
Any comment on bizhub 350 ? :confused:
JR2ALTA
07-15-2012, 04:27 PM
They are really no surprises left with the 200, 250, 350 models.
Drums and developer are relatively cheap and as slide in/out like a printer would.
Feed systems are a contraption but realiable. Fusers can't be rebuilt. Stock each board.
Hansoon
07-15-2012, 05:51 PM
When trained it takes about 30-40 Minutes to do a fuser rebuild. Fusers over 500K sometimes become brittle. We use Katun UFR's which are not bad.
Hans
fixthecopier
07-15-2012, 10:30 PM
Hans
I was going to reply to that. If you work for a cheap enough shop, anything can be rebuilt.
Copyjaya
07-22-2012, 07:01 AM
few days running on that copier , feel quite good . but the memory seem not enough if you meed to copy many !
Maybe need to install a Harddisk kit ?
Hansoon
07-22-2012, 10:35 AM
I'm an Indy and yes, I'm cheap........., I must be.........
:rolleyes:
Hans
Copyjaya
09-08-2012, 01:14 PM
really take long time to rebuild the fuser .. :(
Hansoon
09-08-2012, 01:40 PM
What do you call "Long Time"? I just yesterday did one in not more than 30 minutes.
Since often the UFR gets prematurely scratched by the thermistors but the rest of the unit is still OK I believe its worth the time to replace only the UFR instead of swapping the whole fuser unit.
Aftermarket UFR's can be obtained easily and cheap.
Hans
Copyjaya
09-10-2012, 10:48 AM
maybe first time did it .. it took me more than 30min.. hehe..
i think after few more times practices it will be faster .. :o
Copyjaya
09-14-2012, 03:14 PM
Anyone here know how to setup the " user & password " for the bizhub 350 ?
Many thanks for your time... :o
Hansoon
09-14-2012, 06:11 PM
User manual Chapter 11.7
Hans
