View Full Version : Dead Machine Konica Minolta c5501 (c-2834)
O sentinela
03-19-2012, 04:11 PM
hello.
I have a problem with a Konica Minolta c5501. this code with the C-2834.
Already changed the Drum potential sensor board
/ C (DRPSB / C)
Drum potential sensor / C
(DRPs / C) and already changed the charge corona and the drum.
Any suggestions!
Anular edições
blaze2000
03-19-2012, 05:49 PM
SOLUTION: Perform the following adjustment:
1. [Utility].
2. [Machine Admin. Setting].
3. [System Setting].
4. [Expert Adjustment].
5. [Process Adjustment].
6. [Toner Quantity / Exposure].
7. Select the proper Exposure Adjustment [Yellow, Magenta, Cyan, or Black] by using the Next/Previous button.
8. Select Standard then select [-2] under Exposure.
9. Press OK.
Notes:
a. If the problem persists, replace the problem color drum since the cause of the SC is the combination of drum characteristic and humidity.
b. The following codes = colors: C-2831 = Yellow; C-2832 = Magenta; C-2833 = Cyan; C-2834 = Black.
O sentinela
03-22-2012, 01:07 AM
thanks for the suggestion!
that day I changed the drum and the problem was solved .... did not know this but for the next set already know! seen that the drum is already at 250% could also be causing the problem!
thanks anyway ....
