View Full Version : Bizhub 600 Jamming
Bizhub 600 Jamming from trays 1&2 only. Codes 3101 and 1701.
MCBIG
03-21-2012, 01:15 AM
Subject:
Jamming consistently from Tray 1, Tray 2 and the bypass. Feeds properly from Tray 3 and Tray 4. Jam code may be either J1701 or J1001.
Description:
J1701 or J1001. Jams every time from Tray 1, Tray 2 and the bypass.
Solution:
CAUSE: Failed PRCB (Printer Control Unit).
SOLUTION: Replace the PRCB (p/n 57AA -902 1J).
or maybe....
Description:
J3101 codes.
Solution:
With paper stopping at the registration roller.
CAUSE: Worn shaft on Registration motor (M5).
SOLUTION: Replace M5 (p/n 27LA 8001 2E for bizhub 600/750 and p/n A0PN M102 00 for bizhub 601/751).
EarthKmTech
03-21-2012, 09:30 AM
Subject:
Description:
Solution:
I've had this, but jamming from ALL trays except bypass and large capacity tray option- the drum separation solenoid is on the same ICP as the vertical transport clutches.
The separation solenoid cracked away from the housing and was smashed into the back of the machine by the customer closing the ADU. when it activated next it shorted to ground blowing the ICP. DO NOT just replace the PRCB if the icp is blown with out at least visually checking everything else on the same ICP, or dollars will go down the toilet.
Subject:
Description:
Solution:
or maybe....
Description:
J3101 codes.
Solution:
Thanks MCBIG. I had already replaced the board and M5. It turned out to be the one way gear (56AA 7716 0 BY PASS FEED INPUT GEAR A 24T0) on the Manual Feed Unit that needed replcement.
Thanks Perth. It turned out to be the one way gear on the Manual Feed Unit(56AA 7716 0 BY PASS FEED INPUT GEAR A 24T0) that needed replacement.
