View Full Version : Error Code Bizhub Pro 920
hosbiz
03-21-2012, 11:13 AM
I'm having this Code SC 90 -01 on Bizhub 920.Check the ICP's on Main Board and ADU board and found them all OK. Checked also the voltages going to the ADU board -all are Ok. Any suggestions please.
blaze2000
03-21-2012, 02:37 PM
If ADU is good, you may be looking at replacing PRCB.
O sentinela
03-22-2012, 01:19 AM
clean the memory ddr or charge de firmware!!
otomatic
04-25-2017, 07:16 PM
got the 90-01 on one of our machines and swapped out the adu board and the code cleared but now the fuser will not light up and stuck on copier warming up
if I put the old board back in and start the machine in tech rep the fuser works but nothing on the adu works I exit tech rep and it kicks the code again
I did find a blown fuse on the old board and replaced it but still did not work
is there some sort of reset I must do when changing these boards?
I also have changed the printer control board to no avail
