View Full Version : Scan to email KM bizhub c350
TonerMonkey
06-20-2005, 11:25 PM
Anyone had the problem with \'Transfer Error\' in the scan log after setting up - customer has exchange smtp server on a remote subnet and say everything in the domain should be passed through by mail server, can scan ok on laptop and x-over cable - suspect may be a routing problem? customer thinks their connectivity\'s ok because they can see the copier web page.
Heeeeeeeeeeeeeeellllllllllllllllllllllllllllllllpp pppp !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
CMB
06-30-2005, 11:34 PM
Model: C350
Solution ID: 181761
Type:
Created: 08-12-2004 at 12:43:47
Last Modified: 08-18-2004
Description:
\'Transfer Error. when scanning to email.
Note: Scanning using the internal controller without an additional hard drive. Message occurs with JPEGs and Adobe* Acrobat* PDFs
Solution:
CAUSE: Only single page documents can be scanned to a C350 with no hard drive and a \'From\' email address must be provided.
SOLUTION: When the administrator is configuring the SCAN settings they must set \"Scanned file Separation =\" to YES. A \'From\' email address must be provided as well.
*Trademark ownership information
Tonerbomb
07-01-2005, 12:38 AM
:pinch: :pinch: Check the subnet, gateway and DNS settings!! :evil: :evil: :evil:
TonerMonkey
07-01-2005, 02:12 PM
Many thanks for the info, I\'ll have a go again at configuring this for email with these limitations in mind but suspect might have to try and set up FTP or SMB instead as the machine has no HDD.
