View Full Version : I have to reinstall the system software on a PI5500 controller...
Pages : [1] 2
diogenisS8
11-20-2007, 02:23 PM
and I do not have the parallel cable required or the Ssystem software ver 2.0. Can anybody help me finding them?
jerryblack
11-21-2007, 01:32 AM
It's a parallel to mini-centronics IEEE 1284, be sure to set in your computer's BIOS the parallel port to ECP or Bi-directional.
diogenisS8
11-21-2007, 04:33 PM
I just ordered the cable, but do you know where to get the latest System Software From?
pepper38_cnd
11-23-2007, 01:43 AM
The only thing I see on the KM web site is System Code Version 2.0 released March 23, 2005 The file is an ISO file 201.7M
If that is what you think you need let me know and we will figure out a way of getting it to you.
diogenisS8
11-23-2007, 01:47 PM
Please let me know how can I get it.
pepper38_cnd
11-24-2007, 03:53 AM
I am transferring the file to your FTP
diogenisS8
11-24-2007, 07:28 PM
Minolta and EFI could not help me but you did!!!.
pepper38_cnd
11-25-2007, 07:42 PM
I did find a reference to 3 patches for the Pi5500. See attached. But I could not find the actual patches anywhere, are you sure they are not included in the CD?
diogenisS8
11-25-2007, 08:03 PM
Before I had to re-format the hard drive, the configuration sheet under the update information paragraph used to say 1-5Q7BX (24 APR 2002) and 1-9O0A7.The Cd you sent me has no information on those updates, and now the config sheet shows no updates. But based on the sheet that you sent me since this server is connected to a Di550 and since there is no computer with windows NT unless the NT patch is necessary for windows XP as well, the only update I need is the 1-21OPR and may be update 1-5Q7BX. Any idea where I can get those from?
Thanks.
pepper38_cnd
11-25-2007, 08:53 PM
I found a whole bunch of patches, check PM for my download link.
diogenisS8
11-26-2007, 01:18 AM
After reading all those release notes of all those patches I realized that they were the ones I needed from the begining, and not the whole system software. The server was acting up and I thought that something was wrong with its memory HD etc, and after I took everything appart and I checked that all wires simms boards were seated correctly I concluded that I had to reformat. For 15 days now I spent hours on this server and the copier trying to understand what was wrong with it. When I bough this machine from ebay about a year ago the server had an admin password and I could not log in to set it to my environment. Since I had no idea about the system software, no manuals, and since EFI was not helpfull on the phone at all, I removed the hard drive I setup a Linux machine (for the first time I had to figure out how to work on a Linux OS) and I started digging in the files to remove the password. I managed to do that. But the server was acting up and I though that it was because of the inappropriate digging to remove the admin password. Typical problems were "restarting" "freezing" and copier freezing on scan mode. I was always telling my self "what did you expect for $100". But the copier its self is in pretty good shape ( have it for a year now and never had a problem) and Minolta is a good brand so I kept trying to resolve the problem. For the last couple of weeks I was determined to find the solution. Thanks to you I think my machine will run without any problems from now on. I will apply the patches that I find approriate for my environment and I will keep you posted. :)
Thanks again,
Chris
pepper38_cnd
11-26-2007, 12:26 PM
I'm glad it work out for you:)
If I'm ever in NY I'll take you up on the beer and Greek Food, sounds great to me.
diogenisS8
11-26-2007, 02:50 PM
Don't loose my #
diogenisS8
11-26-2007, 10:42 PM
I re-installed the system software 2.0. The pi5500 was still rebooting restarting and hunging. I was desperate. I was thinking to just drop the idea of having the print server working and I thought to give it a last chance before i place it in the basement. I was doing diagnostics test email, and the email was not reaching my desktop. I knew the configuration was correct because it was working (not perfect but bearable) up until 3 weeks ago. So I thought to take a look on my exchange server. The fiery mailbox was flooded out by a misconfigured surverylance system that i had installed 3 weeks ago. I turned the email alarm of the surveylance system off and kaboom. Here it is, my printer server is back and working.
I installed these updates 1-4KLNC, 1-2IORP, 1-632RA, 1-7WUW1, and
1-9O0A7. The server now is running GREAT!!! no hickups no problems. The only one I would install (if I find it) is the 1-5Q7BX. It should be noted that update 1-632RA would make my problem go away from the begining. Thanks to pepper38_cnd help I have my server back running better than before.
jgspeer
12-07-2007, 03:24 PM
I'm not a service tech but I am skilled with computers. I am looking to update my Fiery PI5500 with the newest system software (2.0?). Also I'm looking to go paperless in our office. I have a DI450 Copier and Twain commander software.
The Twain Commander Software enables me to program in commands in VB code so no user intervention is needed while scanning. I can still do it with the copier, but it requires user intervention. Instead of it scanning and then having to retrieve it from the Fiery unit, I would like it to just scan basically like any typical desktop scanner. If that is possible.
Thanks in advance
Joshua
P.S. Or if there is a way I can use command line options with Fiery scan 5 that would be helpful to know as that could eliminate the user intervention. I've looked everywere for 2 days and can find nothing useful.
pepper38_cnd
12-08-2007, 12:25 AM
Hey Joshua
I will do what I can to help, just a little more info. What version are you at? If your system is still working do you know that an upgrade will benefit you (if it aint broke don't fix it)? There are a ton of patches, is it possible all you need is a patch?
As for the scanning, I'll be honest I am a Konica Tech and not overly familiar with the Minolta products. But I will do a little research, if that product supports scan to PC SMB ( Scan directly to folder on pc or server) that is the way I would recommend scanning.
Some one else has requested the patches so I will email you a YouSendit link to the patches as well, link will only be good for 5 days so download them as soon as you get it. Make sure you read thru all the read me files before applying any patch.
Let me know how you made out.
jgspeer
12-08-2007, 12:30 AM
Hi! Thank you for responding. The current version is 1.1. I've seen images of the interface for the fiery that has the 2.0 version and it has a scanner tab, whereas mine does not. Nor does it say anything about scanning. Under WebTools I can access scanning functions but it is very limited.
Thanks!
Josh
pepper38_cnd
12-08-2007, 12:52 AM
Josh
Check your PM's
costi010380
09-02-2008, 02:32 PM
Hi, I'm a junior service tech and I have a problem with 2 Pi5500. One of them has the HD full and i couldn't find a way to clear the stored jobs. The other one has the System ver. 1.1 and i need the 2.0 ver. in order to scan and manage documents on my DI 450.
Please if anyone can help me!:(
poizzon
09-18-2008, 01:11 PM
may somebody can help - crashed HDD, try'ing to restore but didn't have any cd's..
hardware is :
Fiery Pi550
Model mxi-01
Part number 45025807
Andrusa
10-26-2009, 02:45 PM
Please, I need that iso too, how can I get it ?
I have pi5500 mxi-01
jeffee1
01-12-2010, 09:43 PM
the trusty pi5500 crashed on us. Think it's the HDD, I'd like to try reloading the OS before we spend any $$ on it. Can you help?
thanks in advance!
criscasmo
01-14-2010, 04:25 AM
Hi, I have a fiery server model MXI.01 too, did you have any repair manual I think that the problem is the HDD because the sys do not start and the hdd led do not link.
The idea is remplace the HDD and install the OS
fldevs
03-17-2010, 05:30 PM
I need to update/reinstall the software for our pi5500 as well...any help would be greatly appreciated!
NG_tech
03-26-2010, 07:08 PM
My pi5500 hdd crashed down, so I need system software files.
Does any body knows if a bigger disk than 10Gb it is supported by the pi5500?
Thanks in advance.
Hansoon
03-27-2010, 05:21 AM
Thanks in advance.
We have them around with 20 and 30GB disks, no problem.
Hans
NG_tech
03-30-2010, 01:35 PM
Hans,
Thanks for the info.
NG_tech
Lorian
04-21-2010, 08:33 AM
I also need this software. Kindly please send me link
THanks,
Lorian
FlyHi
04-28-2010, 01:01 PM
I have the same problem, please help. Тhanks in advance!
NG_tech
04-29-2010, 09:33 PM
Chech your PMs
NG_tech
04-29-2010, 09:34 PM
Chech your PMs
Eledu
05-20-2010, 12:01 AM
Hello sorry for my English I'm from Argentina I wanted to know if anyone has the patches for pi 5500. Thank you very much
NG_tech
05-20-2010, 03:24 PM
Chech your messeges.
ceugen
08-03-2010, 06:45 PM
Any help would be greatly appreciated!
Thanks in advance.
thboyes
08-17-2010, 04:07 PM
I need the system software download link.
Thanks!
NG_tech
08-18-2010, 04:13 PM
Chech your PMs,
Ng_tech
NG_tech
08-18-2010, 04:14 PM
Thanks in advance.
Chech your PMs
NG_tech
NG_tech
08-18-2010, 04:15 PM
Thanks!
Chech your PMs
NG_tech
milk111
09-04-2010, 11:49 AM
I need the system software download link too.
Thank you in advance!
ceugen
09-06-2010, 05:44 PM
milk111
check your PMs
ceugen
sorinelmelinte
04-04-2011, 06:58 PM
i need system software for pi5500 pleeasee
jeffee1
08-03-2011, 07:40 PM
Ditto.
Thanks in advance!
Andrusa
02-03-2012, 08:50 AM
Hello, I have a similar tech problem.
pi5500 with di450
Rebooting and rebooting...
I change the hard-drive with a 20Gb one.
Please guide me to reinstall the software.
TheOwl
02-07-2012, 10:08 PM
Find Manuals4You as he will probably have a service manual for that controller.
The service manual tells you everything that you need.
Andrusa
02-08-2012, 01:17 AM
Yeah, thanks, You help me like a pain in the ass...
TheOwl
02-08-2012, 01:47 AM
Well fix it yourself then.
I'm trained on the Fiery Print Controllers for Konica Minolta, Toshiba and Canon. I use the service manual which guides me through the process, so why are you too good to read it?
JustManuals
02-08-2012, 07:34 AM
That's some attitude you have. Especially that you're new and asking strangers for help. Personally, I wouldn't piss on you if you were on fire.
Andrusa
02-08-2012, 05:15 PM
It is normal to react that way. I asked for help and he sent me on a site where to buy textbooks. What kind of help is this ? What help has given me? So I know where to buy several. I wanted to do it myself, not pay others.
Avskrap
02-08-2012, 05:26 PM
It isnormal toreactthat way.Iasked for helpand he sent meon asite where to buytextbooks. What kind of help is this ? What helphas given me?SoIknowwhere tobuyseveral.Iwantedto do it myself,notpayothers.
If you grasp the basics of reading and learning, you'd understand how that would help you.
ni311
02-08-2012, 07:08 PM
Are you using the copier to make some money, right? So, what is so awkward to pay for something that you need, in order to produce money? If you thing that is too much, go out and call a trained tech. Most likely, he will ask for money too, I don't believe we will help you for free.
