Minolta Di 3510 duplex jamming
  • A\ztech
    • Feb 2011
    • 57
    Hi Guys I have a customer with a di3510 duplex is jamming. works fine if They only do two at a time, but when it does 3 or more the paper jams in the fuser on second side. switched out switch back sensor, upper transport and lower transport sensor. Any ideas would be appreciated thanks in advance
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: Minolta Di 3510 duplex jamming
    how is the lead edge registration on the prints ?
    if there is ANY shift at all replace the registration clutch.
    • A\ztech
      • Feb 2011
      • 57
      Registration is good its not varying. (Question do they call the registration roller a synchronizing roller in the manual)
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        that's the one.
        failing registration clutch usually presents itself as "duplex jamming" on this model and all versions that followed its design. The customer almost never see's the fact that the image is shifting wildly all over the page.
        sounds like yours may be a different fault though. Be sure to let us know what it was when you fix it.
        the only other duplex relaited issue ive had on these engines is the actuator on the turn over section popping out of position or missing its spring. I actually keep these in the car they fall out so often, (same all the way up to BH-501)
        • fixthecopier
          ALIEN OVERLORD
          • 4714
          You can have a clutch failure in the duplex itself. Put the paper in the tray in landscape direction and see if it runs better. Running paper longways slows the machine down and week clutches will run better. Common problem on Bz420/500.
          • EarthKmTech
            Step aside, noob
            • May 2009
            • 2139
            It appears the 3510 adu looks very similar to those troubled versions on the 420/500 that were over packed with grease from the factory destroying thr clutches.
            Ive personally never had failed clutches in the adu's of 2510/3510/b250/b350, will be interesting if thats the cause, let us know what happens
            • mo0651
              • 1054
              The duplex clutches are the same as the drawer clutch. watch thru the vents of duplex to see the paper passing thru. It should stop at the same place every time and pause. If not its the clutches. There are 2 of them, change them both.
