View Full Version : Konica 8050 Sc45-20
FINECO
11-21-2007, 11:48 PM
I have an error, what does this mean and how do I make it go away?
Please Help.......
knightfall
11-22-2007, 02:52 AM
your Color registration correction results in abnormality. Would try first:
1. Clean everything in the process unit(drum, charge, dv units) while in there inspect everything.
2. Clean the color registration sensors.
3. Run process control (Auto Gamma Adjust in 36 mode)
other possibilities:
PRBC or color registration shutters or the sensors PS8 & 9. use I/O to check sensors. Good luck.
Don't do the following if you are not a technician.
random
11-22-2007, 05:26 AM
The colour reg sensors are dirty (usually at the back) or the belt is stuffed.
FINECO
11-22-2007, 05:40 AM
Thanks guys.
I'm not a tech but I'll do my best..... worst case, I have to get someone come in..any clue what a service call will cost?
knightfall
11-23-2007, 12:03 AM
will vary depending on what service company you go to, so shop around for best price. Good luck.
Livebychance
12-02-2007, 01:21 PM
After you do the above mentioned do a auto color registration in the service mode.
36 mode
Image Adj
Timing adjust
Auto Color Registration
