View Full Version : Bizhub 250 Admin code
LennoxD
04-05-2012, 03:44 AM
How can I reset the admin code to access the Utility counter. I need to clear the drum count after drum replacement
morpk
04-05-2012, 04:01 AM
why do you need to reset the admin code normal code would be 12345678, or 00000000
LennoxD
04-05-2012, 12:40 PM
The customer mentioned that the last tech could not recall the admin code thats why I wanted to know how to reset thinking that i was probably some unsual number. Thanks
acusso1234
04-05-2012, 03:30 PM
Normally it is 00000000 (8 zeros).
I only want say that if you reset drum counter now that the new drum has worked, probably you'll run in a C2557 code...
Better for you to set the bit 3 from 1 to 0 in 418 soft switch settings avoiding in this way the reminder to change the drum..
JustManuals
04-05-2012, 08:56 PM
Just Manuals ~ The Internet's largest selection of manuals ~ Instant Downloads (http://www.justmanuals.com)
Paul@justmanuals.com
LennoxD
04-25-2012, 11:03 PM
to Acusso1234; If I was to make changes to the bit setting will I still get the error code C2557? Cause I changed drum, developer and reset counters and after a few hrs the C2557 error came back. One thing that I encountered was the F8 did not seem to work. I had expected the copier to do something besides just beep when I pressed the start button when F8 is on the display.
kingarthur
04-26-2012, 09:04 AM
when you went into F8...was the start button "blue" when you pressed it, if not you haven't done the set up....some of these are a nightmare...for example..i've had some that wont let me run F8 if the RADF is up...
LennoxD
04-26-2012, 03:48 PM
The start button was not blue. when i press the start button nothing happened.
kingarthur
04-26-2012, 04:00 PM
if the start button isn't blue...you cant run the F8...keep the side door open until you are ready to carry out the TCR, only close it when you are ready to press the start button in F8...have you reset the C2557 error..
LennoxD
04-29-2012, 07:32 PM
Got F8 to work kingarthur. Thanks very much.
