Minolta C350
  • shep
    • Sep 2010
    • 108
    Minolta C350
    i have a minolta C350 that is doing smudging cyans, put a new imaging unit in the machine and it still has the same problem. i am a kyocera tech and not really familiar with this problem and not sure how to fix it. it is for a church and with Easter coming up there really wanting me to have it fixed today. any help would be much appreciated.. doc20120405084657.jpg
  • shep
    • Sep 2010
    • 108
    Re: Minolta C350
    notice the blue, green and purple colors at the heavy fill end
    • JSC
      Gimp
      • Dec 2006
      • 618
      Re: Minolta C350
      Use the wand to clean the led's under the drum units, also give the id sensors a clean, they are located under the transfer belt.
      The gene pool could use a little chlorine.
      • mo0651
        • 1054
        Re: Minolta C350
        Remove the IU's and maybe the transfer belt unit. Scrub the led lens. We use alcohol. The cleaning wand may not be enough to clean.
        • shep
          • Sep 2010
          • 108
          Re: Minolta C350
          Thank you guys so much. ;-) if you need any Kyocera info let me know.. thanks
          • shep
            • Sep 2010
            • 108
            Re: Minolta C350
            thank you that solved the problem
