View Full Version : Error Code Panasonic DP3030 E03-40!!!!!
O sentinela
04-12-2012, 04:21 PM
hello guys. I have a Panasonic DP3030 put you a ruler and a drum cleaning and when I ran the f8-14 gave me a code E03-40. And the copies come out with background ..... I need help
O sentinela
04-12-2012, 04:23 PM
hello guys. I have a Panasonic DP3030 put you a drum and a cleaning blade and when I run the f8-14 gave me a code E03-40. And the copies come out with background ..... I need help
mojorolla
04-12-2012, 04:52 PM
Check the 2 sensors under the silver baffle on the right door, near the transfer roller. They are moved up and down by a solenoid. If the silver baffle is not installed right, it can bind the rear and keep the sensors from moving smoothly.
15225
O sentinela
04-16-2012, 02:15 PM
15225
Thanks man i really aprecciate your work and did work....i clean the sensor and the problem it's solve ;) thanks again....
