Command work station for IC305
  • gamalmehdar
    • Mar 2008
    • 55
    Hi every one:
    How can activate reprint jobs on commond work station with fiery IC305 in bizhub C6501 >
    now all the job has finishe i cannot controll it ? like when i need to print this job agai i didnt??? its gread out//
    how can chang the setting to the active?
    thans for every one
  • methogod
    • Dec 2008
    • 915
    Re: Command work station for IC305
    need more information to help....
    sometime its the computer, try intstalling on a different pc.
    see if you get the same results.
    GREYED out usually means you lost connection.
    not sure though a screen shot would help some....
    • gamalmehdar
      • Mar 2008
      • 55
      dears:
      the machine is printing well?
      but only i cannot use the completed job from comand work station?? its means if i open comand work station folder then right click on the job?? this action not effect.
      so from where can make it effect.
      • TheOwl
        • Nov 2008
        • 1732
        How are you logging into Command Workstation?
        Are you logging in as the Administrator / Admin, Operator or Guest?
        • RRodgers
          • Jun 2009
          • 1947
          As Owl has stated above, it all depends on how you are logged in. Don't ask us what the password might be, we wouldn't know. We only know the default one.
          • dljorg
            • Sep 2009
            • 93
            No solution but can share an observation. Just tried to log into CWS 5.3 / IC305 as Guest and printing was not possible. Jobs were visible but print icon was grayed out. Right clicking on jobs did not produce a menu. Operator and Administrator had rights to reprint jobs and an active print icon - nothing grayed out.
            Operator should not be too tough on the password - just click OK.
