KM Driver for C550 Problem Data-Sourced Copies
  • robdun
    • Apr 2012
    • 3
    Hi
    We have a Bizhub C550 which we use for printing barcode labels and card-stock.
    We use barcode label printing software called Bartender which works fine with Lexmark PCL driver. When we try to print to bizhub, the quantity of labels requested from bartender should relate to sheet design, so if Bartender software is set to print 500 labels (the label quantity to be printed field, comes from a database) and there's 10 labels per sheet, then the printer should print 50 sheets, 500 labels in total.
    This works fine when printing to a Lexmark PCL printer, however when I try to print to Bizhub C550 the quantities are all wrong, I may just get 1 sheet or 500 sheets, there doesn't seem to be any rhyme or reason to what quantities come out.
    So As a work around I currently have to print to file to the lexmark driver, then use Raw Print do send the .prn file directly to the Bizhub.
    Anyone know if there's an alternaive KM driver, which solves this problem.
    Regards
    Rob
