View Full Version : Wavy paper on last 4 inches
CopyQ
05-07-2012, 12:54 PM
End User having problems with Ld-6500 putting a wave in the last 4 inches of 11 X 17, techs have spent hours in it, no luck. Brought out a used finisher and same thing. I think the issue has to be in fuser to form such a perminate wave. Now there talking about swapping the entire paper transfer/duplexing/exit unit with a used one, not sure I want these older parts on my machine. Have attached photo of a program we are working on. Right now I have to take the finisher off and run sheets flat. Then run them through my folder, hand collate and stitch. Once again I have to find out how to fix my machine. thank goodness this forum always has answers.
minoltaed
05-07-2012, 09:30 PM
Lower fusing roller.
acusso1234
05-07-2012, 10:47 PM
Lower fusing roller breaked bushings ( I bet only the rear one) :D
HoonBoy
05-08-2012, 10:14 PM
Did they lower the fusing temperatures? Any difference in face up / face down output? Could also be the exit roller, straight after the fusing...
kyrenecopy
05-08-2012, 11:17 PM
If it only does it with the finisher on then it must be the finisher. Unless I misread/misunderstand what you are saying. If it only does it when the finisher is on it then I would suspect that the paper is slowing down in the finisher allowing it to be in the fuser too long.
