bobe
05-11-2012, 04:07 AM
Hy
I have a new konica C745 and I wanna know what do I have to setup for VoIP. This is the same setting for all Fax boards.
VoIP is still not supported offically by Konica Minolta, but may work in some instances.
Performing these suggested settings may solve the problem. Follow the step-by-step procedures:
From Service Mode:
FAX Settings => Communication => Protocol set "ON" for the "V.29 EP Tone" Protocol and set "OFF" for all other faster protocols.
FAX Settings => Communication => Others we have set "OFF" for the "ECM Function"
FAX Settings => Function Parameter => Address "000e0012 = 01111000 (decimal 78 = 120 sec) for T1 Timer for Calling
FAX Settings => Function Parameter => Address "000e0013 = 01111000 (decimal 78 = 120 sec) for T1 Timer for Called
System 2 => Software Switch => SoftSwitch 21 Bit 5 =1 (HEX 20 = over 4.5 sec) for T4 Waiting time between start Identification
From Service Mode:
