View Full Version : Bizhub 350 image problem
brianho80
05-12-2012, 05:51 PM
Hi Expert,
Does anyone what happen to the machine according to the image?
i had tested print from demo page / PCL font print and PCs; nothing happen.
It happen intermittent and only happen when customer doing printing, not happen when technician was there to do testing.
anyone can advise?
15819
acusso1234
05-12-2012, 07:39 PM
Are you sure it is not a copy done using the Automatic Document Feeder (ADF)?
Seen this when adf is not parallel to the scan area.
If really it is a print, then ceck fuser unit entrance guide for foreign things like toner melted and clean the registration roller as well.
Hansoon
05-13-2012, 06:18 AM
The shown sample MUST be a copy through ADF. Nothing else is possible. I cannot imagine that paper moves laterally during the copy transfer process.
The ADF is mis aligned and/or the height must be readjusted with the screw on the left hinge so the white guide plate lays flat on the glass.
Hans
brianho80
05-13-2012, 07:41 AM
Thanks for the advise,
Will try do some testing again on adf and fuser
mo0651
05-14-2012, 05:15 PM
Look for missing spacers on the white plate that sits above the narrow slit glass when you are using the adf.
kingarthur
05-15-2012, 02:49 PM
Adjust the RADF according to the set up procedure, using a thin piece of paper, it works every time...
