tekkie
05-14-2012, 08:21 PM
KONICA MINOLTA Bizhub C35 jams every copy on duplex its ok on single sided but on 2 sided it feeds out through the fuser unit then kicks back in to refeed and jams just has it starts to go into duplex guide on side door.The paper is not been physically stopped there is no obstruction the duplex guide and feed are all free you can manually feed paper through.The paper isnt hitting anything nor is it folded or damaged it just jams.
I have checked the sensor above the fuser unit which seems to be the only sensor that is used solely when duplex is used as a pose to single sided. Not got much experience on this particular KM model as we only have a couple out in the field.
Hence any help would be much appreciated.
