C452 disable "replace image unit" meassage
  • Kevin12
    • Nov 2011
    • 8
    [Misc] C452 disable "replace image unit" meassage
    Hi
    Ive had a look around the forum and believe the message "replace image unit" can be disabled and it can be done using the "soft switches"
    I unfortunatly cant seem to find the the locations of those soft switches anywhere in the the forums.
    Can someone please inform what the values of those soft switches for the C452, 552,652 machines.
    Thanking you in advance.
  • Shadow
    PHD in Sh!t Disturbing
    • Sep 2011
    • 455
    Re: C452 disable "replace image unit" meassage
    you need the correct firmware for each model of machine. with the firmware are the settings for the soft switches.
    $hit Happens - Deal with it and move on.....................................sigpic....................................Lock & Load
    • Kevin12
      • Nov 2011
      • 8
      Hi Shadow
      Thank you for your reply. I have in the past loaded the firmware for the C451 to "disable the IU message" and changed soft switch 51 which worked perfectly.
      Do you know what ver. firmware is required for the C452 or is it a special program, if so what is the version of that program? The particular machine I want to achieve this on is now on FW-VE​R_D1_MASS_​PRODUCTION. In the PDF it doesnt mention any soft switches to Disable the message.
      • Shadow
        • Sep 2011
        • 455
        the C452 needs version GC6_C5 Program filename - C452_C552_C652_A0P00Y0-F000-GC6-C5.exe
        • Kevin12
          • Nov 2011
          • 8
          Ive read though the PDF, but have not seen any soft switches that need to be configured for the "IU message" are the switches the same as the C451?
          • Shadow
            • Sep 2011
            • 455
            DLBT1102652EN01.pdf
            • JustManuals
              • Jan 2006
              • 9932
              Paul@justmanuals.com
              • Kevin12
                • Nov 2011
                • 8
                Originally posted by Shadow
                [ATTACH]15884[/ATTACH]
                Great sorted.
                Thanks Shadow.
                • charly
                  • 65
                  Hello, I've been looking for the firmware GM6-31 in d-box web and CSES and have not found anything, please where I could find it.
                  D1 firmware maybe take active switch software 51???
                  thank you very much.
                  • Kevin12
                    • Nov 2011
                    • 8
                    Hi Yes Firmware D1 does activate the soft switch 51.
                    • charly
                      • 65
                      thanks you very much.
