View Full Version : Bizhub 250/350 drum scracthed
brianho80
05-17-2012, 06:10 AM
Hi All,
does anyone always face the problem drum scratched at the edge of drum which cause of toner leaking?
I just replace drum and developer unit not long ago but after sometimes, return to check the machine, saw the drum scratched at edge, even though i doesn't effect the print out but it cause toner leak and the scratched part will getting bigger after a period.
i believe it caused by the hinge at registration roller; does anyone often face this problem? and how to prevent it?
15875
PeterG
05-17-2012, 07:31 AM
Check out this thread.
http://www.copytechnet.com/forums/konica-minolta/9888-bizhub-250-350-eating-drums.html
You can fit a ds-roll kit available from KM
armstrong
05-17-2012, 09:00 AM
I think you should have to replace the drum, developing unit and developer too. Your machine might be overloaded.
ineo+6501
05-17-2012, 09:10 AM
You need to change the transfer roller on the door as well as the drum & dev.
11 - 4163529801 roll15881
if you change these rolls you solve the problem
Darren King
05-17-2012, 01:41 PM
In my experience it really isn't the worn spacer rollers that cause the wear on the rear of the drum. It is the transfer roller. There is a white guide roller that wears and causes extra pressure to be applied to the drum surface.
The worn spacer rollers do cause issues though and they should be replaced as well.
Darren.
i just modify Di350 IU
then drum, develper unit and developer are replaced all at once
SmellsHot
05-17-2012, 08:05 PM
Collars in Dev unit and white guides on transfer roller will do this. Make sure to replace both. You can tell when the transfer roller is the problem the white guides are grooved into....
brent
05-17-2012, 08:27 PM
how much more money is the di 350 unit? I have read that you can put these in. but I thought they cost right at 299 bucks? outch
what kind of modifications are needed to install this?
brent
Hansoon
05-17-2012, 08:51 PM
The ATDC sensor build in the image units of the previous series will NOT work with the Bizhub 200, 250, 350.
From KonicaMinolta Solutions:
"Solution ID TAUS0801978EN* Solution Usage 5
Description
C-2557 (C2557) after replacing a defective ATDC sensor.
Solution
CAUSE: The wrong ATDC sensor was used. The Di3510 series of machines ATDC sensor looks identical to the bizhub 350 series but they are different and
operate in a different voltage range.
SOLUTION: Please use the correct ATDC sensor (p/n 4040 6040 01)."
Hans
