View Full Version : toshiba e studio 810
dqydj
07-20-2005, 07:13 PM
I\'m currently fighting an Imagistics IM8130 (Toshiba E Studio 810).
The first copy out looks ok but the more you run, the copies get lighter
and washed out. As they get lighter the machine starts pulling developer.
Seemed like an easy fix. I checked developer bias and it was at -355 vdc
it should be -480vdc and it wouldn\'t adjust so I replaced the high voltage
tansformer, set the bias to -480 and it didn\'t change a thing.
Here\'s the list of parts relaced to date.
developer, developer unit, drum, cleanig unit, hv transformer, drum potential
sensor, image quality sensor, logic pcb, system pcb.
I gotta admit that I\'m stumped. It seems as though the charge is
building up on the drum but the ground is good and the cleaning lamps
are working fine. If any one has any ideas I\'m open to all suggestions.
Post edited by: dqydj, at: 2005/07/22 16:34
dqydj
08-10-2005, 03:37 AM
I figured it out.
turns out that the e-prom on the logic board was the culprit.
I had changed boards ( as most of you know,)
new boards don\'t come with the prom) so all I did was
transfer the problem to the new board.
I kept stareing at that chip and decided to pull it off one
that we had in our warehouse and I\'ll be damned if it
didn\'t fix it.
It\'s something for you toshiba guys to watch out for.
These things have had alot of chip failures in the field
for us but nothing like this.
it\'s usually fuser codes when there isn\'t any thing wrong with the fuser and also hard drive codes.
codes.
I hope this helps anyone who has weird things goin on
with these toshibas
good luck...
I think I\'ve been doing this to long...
When I have a problem like this I tend to go to the
old tried and true copy process.
well with the way the things work now
you can\'t rule out the electronics.
good luck...
Post edited by: dqydj, at: 2005/08/09 19:48
