Konica Minolta KM7222 print trouble
  • puczol
    • May 2025
    Hi
    I've got problem with this printer. Few years it works correctly, three monts ago I'd reinstall one computer and something wrong was happend.
    Can't print anything, print list dialog box says me: "printing" "printing - restart" "printing""restart" and again, and again, and again.
    Today I had to reinstal good working printer on other machine, and I had the same state :/
    Printer is connected by tcp/ip, every thing is ok., ping works correctly with ip and dns name, I think drivers is ok too, because it worked few years with it, maybe something wrong with system (w2k and xp), but I can't find any solution.
    regards
  • mrwho
    Major Asshole!
    • 4299
    Re: Konica Minolta KM7222 print trouble
    Go to your computer's printer properties, go to Port settings and try to put 10001 instead of 9100 on the port number.
    Mascan42
    Ibid
    • puczol
      I've changed properties and I've get only "print error" message.
      I've tried to do other setting - anything doesn't works
      Printer Computer
      9100 9101
      9100 10000
      9999 10000
      10000 10001
      Anybody has other ideas?
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • puczol
          Anybody knows how to fix that?
          • TheOwl
            • Nov 2008
            • 1732
            It could be that your print controller has packed it in.
            If you are unsure as to the RAW port that the machine uses, try telnet using the below command:
            telnet xxx.xxx.xxx.xxx 9100 - replace the x's with the IP address of the machine.
            If your screen goes blank with a flashing cursor in the top left corner, then you connected to the correct port.
            Other ports to try:
            10000
            10001
            9101
            9099
            Sometimes people changed the RAW port to different numbers.
            You could also try changing the setup of the TCP/IP Port used to print to the machine and use the LPR setting with a queue name of "print" (can someone please verify that the queue name is correct as it has been a long time since I have had to work on one of these machines).
