View Full Version : BizHub 750 - cleaning web not moving
I have a BH750 that the cleaning web on the Fuser is not moving. I've replaced the web because the old one had a hairline crack on the frame and we thought maybe binding was they issue from the crack allowing the frame to flex. After replacement, it still doesn't run. When i run the machine with the doors open, the little U shaped arm never kicks the lever on the cleaning web.
Anyone ever replaced this, or have any insight ?
JustManuals
05-24-2012, 03:03 PM
Just Manuals ~ The Internet's largest selection of manuals ~ Instant Downloads (http://www.justmanuals.com)
Paul@justmanuals.com
907tec
05-24-2012, 05:59 PM
Does the web advance when you move the actuator by hand? If you click that little U-shaped arm about a thousand times, you should see the new web tightening up and then advancing. I've never had problems with the actuator itself, just with the web assemblies.
Mr Patonerhead
05-24-2012, 06:42 PM
reset the web counter in the service mode, also reset the pm counter to zero.
WINNER !!!
Reset count, started clicking away. Doh!
I owe you a beer ... or a job if you ever wanted to move to iowa. serious.
http://www.copytechnet.com/forums/employment/62345-expierenced-tech-wanted-cedar-rapids-iowa.html
