View Full Version : Konica Minolta Stucked on "Copier is Warming Up"
Maindron1
05-29-2012, 10:06 PM
Hi, I just changed the M4 motor because I kept getting a J32-01 jam code and after I put everything together, the copier will not go pass the warming up part, it is stucked there and will go on ready.
Please help.
I am sorry, It is a Konica 7155.
n edwards
05-29-2012, 10:22 PM
Try thermistors, but most likely a fuser lamp has blown - bell out lower lamp and all 3 upper lamps individually -btw did m4 motor fail? I normally clean/replace the 3x 'm' one way gears for a 3201 error?
empiru
05-29-2012, 10:23 PM
I've got a car (won't tell you what model) that won't start. Can you help me?
kyrenecopy
Double check and make sure you plugged everything back in that you removed when you replaced the motor. Make sure you didn't accidentally pull/knock off a plug.
NVRAM can cause this, check all your optional equipment to make sure they are ok. Reinstall any options you may have removed.
Maindron1
05-29-2012, 10:43 PM
mrwho
05-29-2012, 11:05 PM
Some tips:
DESCRIPTION: Intermittent J32-01.
CAUSE: The paper exit driving gear (p/n 56AA77220) is installed backwards. This gear has a one-way bearing.
SOLUTION: Install the paper exit driving gear so the the shaft is driven when the gear is turned counterclockwise
DESCRIPTION: J32-01 when running face up mode. Paper stops in the inversion unit.
CAUSE: The gate switching mechanism on the reverse gate solenoid (SD7) has disconnected which puts the reverse gate in face down mode at all times.
SOLUTION: Remove SD7 and reinstall the switching mechanism to allow proper operation.
DESCRIPTION: COPIER WARMING UP, PLEASE WAIT AWHILE message and the machine never goes to a ready condition. The fuser lamps are ON and cycling properly.
CAUSE: The ADU board has failed.
SOLUTION: Replace the ADU board
Not saying that one of these is the surefire solution for your problems, but are things you might check out.
JustManuals
05-30-2012, 05:15 AM
Just Manuals ~ The Internet's largest selection of manuals ~ Instant Downloads (http://www.justmanuals.com)
Paul@justmanuals.com
