View Full Version : minolta bizhub c280 color copy make blue or red lines
mikon88
06-08-2012, 03:53 PM
Brand NEW KM bizhub c280 color copy make blue or red lines,
Print quality is good, b&w copy is good. When i make a color copy the machine makes blue lines or red lines. This is a brand new c280.Scan to PC is ok, print its ok only copy. Lines are vertical.
Zeldaman
06-08-2012, 04:02 PM
Hi there!
Seems to me something goe´s wrong on the installation. Installate the machine complete new, and very important step by step to the installation-manual! Fellow of me forgoten one step and had exactly the same results!
Greetings...
mikon88
06-08-2012, 04:08 PM
Did you repeat all installation steps again?did you clear any data before?
Zeldaman
06-08-2012, 04:12 PM
Hi there!
No, only turn the machine out & then on again. Then the whole procedure again, then there were no more problems.
Greetings...
kingarthur
06-08-2012, 04:45 PM
you have to follow the set up instructions exactly as it is written down...
mikon88
06-08-2012, 04:54 PM
I will try set up procedure again and i will let you know
Julio119
07-18-2017, 04:57 PM
Hi! Mikon88, did you get this resolved, I just took over a setup on KM C458 it is doing same exact thing you described, thanks.
REGSIS
07-18-2017, 09:02 PM
Read instalation manual. At the end it says to make a color copy and what steps you need to repeat if copy is not OK (if you get cyan & magenta lines).
gl0ryh0und
07-19-2017, 01:09 PM
There are a couple steps that usually get missed. You must do the gradation adjust, and you must do the install date. Do the gradation adjust exactly as it states in the install instructions. If you don't do both copy and print you will get lines.
allan
07-19-2017, 05:53 PM
Who coined the term "lines of shame"?
emujo2
07-19-2017, 08:52 PM
We've been using that term for years...LOL
Synthohol
07-19-2017, 10:20 PM
when they were all blue we called them Yankee Stripes.
Selas
02-05-2020, 10:16 AM
Hi, it is an old thread, but i have similar problem. KM C287 when scanning or copying there are blue or red vertical equal thin lines over the page. Where i should look for problem?
44822
Thanks and kind regards,
44822
Hi, there are thousands of topics where the reason and solution of the problem is explained.
You simply didn't go through the installation steps. Rerun the installation manual step by step and the lines will disappear.
