View Full Version : Firmware Imaging Toolkit vs Cygwin
realmudd
06-10-2012, 07:20 PM
While I'm trying to write in the compact flash (cygwin and command prompt), the system sends a message that says:
mkcf.sh line2: $'\r': command not found.
mkcf.sh line5: $'\r': command not found.
mkcf.sh line15: $'\r': command not found.
mkcf.sh line17: $'\r': command not found.
mkcf.sh line30: $'\r': syntax error near unexpected token '$' {\r' '
´kcf.sh: line30: ' function mount_opt() {
If anyone knows how to troubleshoot, then great. But I'm ready to give up on it and try Firmware Imaging Toolkit except its not there under my search menu as a tech rep. plz send
real.mudd@yahoo.com (real.mudd@yahoo.com)
Darren King
06-10-2012, 08:16 PM
I have never used Cygwin so I can't compare the two, but, the Firmware Imaging Toolkit is a snap to use. If you are a KonMin authorised tech you will find it on "mykonicaminolta.com". It is just a matter of downloading and installing. Then it is ready to use.
Hope this helps.
Darren
realmudd
06-10-2012, 08:38 PM
Hope this helps.
Darren
It's not there under my login. I've seen it in the past, but the link is gone now. I thought it was under construction, but its been over a week now and i cant keep waiting. Any way you can send it to me? Thanks in advance.
mrwho
06-10-2012, 10:24 PM
Are you using the regular Cygwin or the Konica Minolta mini-Cygwin? AFAIK the regular Cygwin isn't apropriate for the job.
kronical
06-11-2012, 01:51 PM
You are correct cygwin will not work it has to be mini-cygwin. I use FIT myself though it works great and easy to use.
907tec
06-11-2012, 07:15 PM
You can find the Firmware Imaging Toolkit in the Konica Minolta MSDS/Drivers/Firmware Section if you do a quick-search for "Toolkit".
