View Full Version : Print Scaning report when use scan to smb on c25 and c20
aligis
06-11-2012, 03:21 PM
hi we have bizhub c25 and c20 when i do scan (smb) it gives me report of scaning job is done correctly, if i turnd off the report of fax TX it do not print report but it turns off the report of fax.TX . what is this.. any one have clue...
:confused:turn on fax TX report doint scan via smb it prints report as well of completing job.
:confused:turning off fax tx report also do not print scan to smb report
thanks..
HoonBoy
06-11-2012, 06:00 PM
For a C25 you would have to adjust soft switch #32 and put bit 5 on "1" (that's on this machine the fifth bit from the left...)
aligis
06-17-2012, 04:54 PM
THanks i will try and let u knw..
aligis
06-19-2012, 06:47 PM
yes its work like charm.. is these bit settings will work also for c20 ?
HoonBoy
06-20-2012, 10:40 AM
Don't know... Should be in the service manual... Never needed to adjust on C20...
