View Full Version : Bizhub 750 toner leaking n too solid
brianho80
06-24-2012, 07:36 AM
Hi, does anyone know why this model always toner drop on T/S block and Mylar at drum unit full of toner.
I had tried to vacuum thoroughly the Mylar n path connect to filter behind machine, drum units etc..
Run this drum peculiar mode and even adjust max density adj = 19
But some how max density will change to 39 after exit to normal mode.
Anyone have other way to solve this problem?
ineo+6501
06-25-2012, 09:46 AM
This is a very well known problem on this model and there are many threads on this subject already.
If the waste section of the drum unit is full, this is usually a sign that the solenoid which drives the coils has failed, replace it.
As for the other causes, a simple search on this website will reveal all of the common fixes.
fixthecopier
06-25-2012, 01:31 PM
I don't know without my notebook, but their is a solution that has you change 2 dip switch settings that will reduce the amount of toner used. Also make sure your grid voltage is correct, especially if you use aftermarket drums.
ni311
06-26-2012, 06:44 PM
This thread might help you:
http://www.copytechnet.com/forums/konica-minolta/3772-konica-7165-7155-developer-dumping-solution.html
