View Full Version : konica c652 has bad data on print only like the wrong driver is being used any ideas
briang
06-28-2012, 08:52 PM
have put new fw and new driver and re intialized the machine
habik
06-29-2012, 01:17 AM
how about screen shot? or
Which of these can you print out and how they look?
1,PCL font list
2,PS font lists
3,test page
4,demo
? List output from service ? if you have all scan it and post it here ;) with also scanned failed print.
can you print the same doc on a different machine? how about different computer?
suspecting MFP Board ..
...Good Luck
TheOwl
06-29-2012, 02:27 AM
I would look at the following:
1. Formatting the HDD (you will need to reload animation data and one-touches)
2. Doing a RAM test
3. Use a different driver. If you are using the PCL driver, try the PS or XPS drivers.
Chameleon
06-30-2012, 02:14 AM
I'll second the RAM test. and add replacing the patch cable.
