View Full Version : CQ Biz hub c500 with too much blue
DUKEEMURPHY
07-19-2012, 09:00 PM
I have a c500 that i have cleaned and performed the color registration on and i cant get rid of a vary fine cyan tint a print of the sky that is supposd to be steel grey is coming out baby blue. after using the manual and before that some cleaning i dont know what to do about it. any advice or help would be awesome.
blackcat4866
07-19-2012, 10:51 PM
So you've cleaned, great. How about replacing something? A good candidate might be the cyan developing unit or drum unit. =^..^=
laserman06
07-20-2012, 01:48 AM
How did you calibrate it? I have found that the best way to calibrate it is with a spectrometer. When you do it off the glass, make sure all optics and mirrors are clean. I have found that the mirrors get a haze on them.
DUKEEMURPHY
07-20-2012, 08:37 PM
Thank you for the input, the solution turned out to be not replacing parts ( they were swapped out about 3000 clicks ago) but downloaded an utility to calibrate the fiery with called command workstation to perform that calibration and after that all was well the unit is now printing beautifully.
