View Full Version : BizHub 7145 with DF318 paper jams.
MHeon71
07-20-2012, 05:34 PM
I have a document feeder (DF 318) that is jamming. It is getting caught up on the paper guide right after the slit glass. The guide guide is broken up into 5 sections with pinch rollers in between them. It appears that it hangs up on the 2nd to rear guide. The slit glass and the white roller right above the slit glass seems fine and so doesn't the guide it is hanging up on. I just don't feel replacing that guide will fix anthing.
Thanks for any help.
minimerlin
07-20-2012, 07:35 PM
Those guide sections do wear and crack, it may also be the rear holder for the white transport roller is broken! The black plastic bits that allow that roller to move a bit, the roller is held in place by the small springs. Also check the height of the feeder is correct.
copytechman
07-20-2012, 08:53 PM
Seconding height of feeder, it'll get bunged up towards the rear of the machine if it's too low almost guaranteed.
Regards!
A.
JustManuals
07-21-2012, 12:41 AM
Paul@justmanuals.com
copiertech
07-22-2012, 05:07 PM
Check the black holder of the white rollers its always get broken, if it still there you can repair it with a thin wire to hold itn we tried this before.
Waleed
