Konica Minolta Colorforce 8050 driver and monitor uninstall
  • yourLSI
    I installed or added this printer to my PC and now I need to uninstall or remove it. I cannot find an uninstall procedure or even find it in the add remove programs in the control panel. Also, I need to get rid of the Job Monitor "virus".
    Could someone point me in the right direction?
    Thanks from a newbe.
  • random
    delete the driver from your 'printers faxes' screen then right click in the 'printers faxes' screen select 'server properties' select drivers choses the driver you want to remove and click on remove.
    A more through method is to do a google search for 'kyocera driver deleter' and download and use this utility to remove all of the little bits left behind.
    • yourLSI
      awesome delete utility - thanks.. did the trick!
