View Full Version : Miscellaneous C5501 and C6500 with IC 408 Windows 7 Driver
drodas78
07-27-2012, 06:30 PM
Hi, I have two bizhub PRO one C5501 and one C6500 both with IC-408 controller. I want to know if there's a Windows 7 post script driver or if it's possible to print with them from windows xp 64 bit edition to use full memory in the pcs.
Regards.
Mr Spock
07-28-2012, 01:22 AM
Fiery needs to be at version 2.0 and depending on service contract this may be costly upgrade.
Then you need the special pcl only driver for windows 7 which supports both 32 and 64 bit versions.
driver is only available via efi and konica minolta tech pages. at least that is the only way I found it.
drodas78
08-28-2012, 08:35 PM
I have installed the PCL driver but is not as good as the PostScript. I have tried with the postscript Windows Vista version but the machines is not working OK, some times took too much time to print and other times don't recongnizes the paper sizes. I'm thinking of going back to WinXp 64 bit edition.
