View Full Version : Error Code reset and replacing fuser unit bizhub c550
vmp007
07-27-2012, 07:28 PM
I did replace the fuse, but my machine is still showing "have the fusing unit replaced soon" what do I do to clear this message... pls urgent help will be very helpful
JSC
07-27-2012, 08:12 PM
What fuse did you use?
swg4765
07-27-2012, 08:21 PM
Which fuse? Did you make sure you were using the properly rated fuse? There is no way to reset the message. It is reset by the fuse blowing.
emujo
07-27-2012, 09:24 PM
1. replace the fuse again with the proper one, or put a new fuser in.
2. if this does not work then you have a bad PRCB..you can check to make sure you have 24VDC going to the fuse to blow it.
3. Install the PPLM mod...MFP will not stop cranking out copies just because some consumable item is past it's bedtime..Emujo
