View Full Version : Bizhub 200 Abort errors and missfeeds after drum&dev replacement
xeroid
07-30-2012, 05:23 PM
Replaced Drum & Developer, reset counters. Had extreme difficulty getting F8 ATDC setup to complete. Abort 0000e0422, 201, 004's and random other codes no doubt. Missfeeds Area O all three trays now. First feed usually works, second sheet can't make it to registration roller. Problem was not there before replacing Drum&Dev. I am in a hole on this one. Anybody got some ideas or experience. Much Appreciated
fixthecopier
07-30-2012, 11:27 PM
It is possible to have a short in the image unit that will do crazy things. I had one that was causing a false code for the fan. I would revisit the drum and look at contacts. Put another drum on it. Since it does not blow a fuse, it won't hut to try that.
xeroid
10-22-2012, 12:04 PM
Problem Solved; Bad connection in Drum Unit. Thanks for the reply
Hansoon
10-22-2012, 12:10 PM
Thanks for the feed back. Which connection? Bias?
Hans
Hansoon
10-22-2012, 12:11 PM
Hans
