pudgi300
08-01-2012, 01:36 AM
This thing started out with a sc29-15. Replace the yellow sensor board and did a recall and setup. Next day the thing comes up with a sc29-13. checked sensoeand board (replaced) and got it to work. Get it all set and get a sc29-11. Swapped out all drums and problem went away. Run for a while and sc29-12.
My main question is when i run drum surface check i see like -034V on magenta and cyan and sometime the voltage goes real high in the hundreds on all colors. Do i have a noise or power supply problem. I cheked and cleaned the carriage connector and cleaned the back wall block. Thanks for any help. Also does anyone have the delta V calc figured out.If you do let me know
Thanks Pudgi300
Thanks Pudgi300
