View Full Version : CQ Procedure lighter or darker....with fiery
dpepin
08-09-2012, 11:10 PM
Hi to all!i have an issue with a bizhub pro 5501, i would like to know if there's a procedure to adjust copy quality.i worked for 20 years on canon products and it seems more easy to get the prints lighter or darker in canon.so if you have a shortcut on how to print lighter or darker with the fiery X3. let me know.thanksDenis
Mr Spock
08-10-2012, 12:14 AM
When is has the last calibration been done? Is it lighter or darker then monitor or previous output? Have you tried the gamma corrections from the driver properties?
dpepin
08-10-2012, 01:05 AM
The last calibration was this morning, the prints are always darker than the monitor, and i don't see any gamma adjust in the driver properties?
the driver is version 1.1a. do you have a more recent driver?
thanks
Denis
Mita-Konica-Tech
08-10-2012, 01:49 AM
I would first calibrate the monitor, before calibrating the Fiery....then as Mr Spock suggests then gamma corrections..
1FRY1
08-10-2012, 10:40 PM
Are the internal test prints ok,
If you want to adjust a the print setup create a profile in the colour setup on Command workstation.
