View Full Version : Scaner disappeared after NVram recovery in C450
CKiiza
08-11-2012, 09:15 AM
Hi all, a c450 machine had error c-d370. I did the procedure for nvram recovery. trouble is that the twain driver can no longer see it(scanner) for scan. tried to turn on everything in network settings but nothing works. SMB works but twain will not work. any Ideas? Thanks
Jazzwcs
08-12-2012, 03:59 AM
Try updating the firmware to the latest level. Sometimes nvram recovery can do some strange things after recovery. If after updating firmware doesn't work, you may need to replace the nvram.
RRodgers
08-12-2012, 07:44 PM
Go into tech mode and re-enable the hdd.
