View Full Version : bizhub 601 maintenance question
brent
08-16-2012, 03:28 PM
I have the service book. question is. I am going to replace drum developer and blade today. do I use the book for adjustments. or the original set up instructions. the service book does not make it clear which way a person should go. because even on initial set up of a new bizhub 601 you do not do all the adjustments in the book. any thoughts? thanks guys. and gals
brent
minimerlin
08-16-2012, 08:02 PM
brentI normally start with the last adjustment first..the developer mix, as my theory is that without a good tribocharge how can you be sure of proper black patches for the remainder of the set-up! I then do the drum blade setting...twice! Followed by the rest of the adjustments in the order in the book! I then run test print 12 as it gives a good grad test. Remember to clear the relevant counters before any set up is started.
regards
C
fixthecopier
08-16-2012, 09:11 PM
minimerlin covered it well. Also if you are using an aftermarket drum, the grid voltage will be way off. A voltage will be on the end of the drum either embossed in the plastic or on a sticker. You must adjust the machine to match. Not hard at all.
brent
08-16-2012, 09:39 PM
I am using oem everthing. I learned onthis model. (well the 5510) actually. it didn't pay to go non oem.
I will refresh with the book.
thanks
