View Full Version : DI5510 14" paper
exCSER
08-18-2012, 05:10 PM
Hi guys,
I've got a machine that wrinkles 14" paper on the lead edge for about 3". The paper is being wrinkled when it is between the fuser and pressure rolls and still being driven by the registration area. The wrinkling stops when the sheet passes the reg. roller. 11" paper runs fine. New rollers. Bearings haven't been replaced (on order), but spun freely. Bushings look just fine. Has anyone seen this?
minimerlin
08-18-2012, 10:21 PM
Hi guys,
I've got a machine that wrinkles 14" paper on the lead edge for about 3". The paper is being wrinkled when it is between the fuser and pressure rolls and still being driven by the registration area. The wrinkling stops when the sheet passes the reg. roller. 11" paper runs fine. New rollers. Bearings haven't been replaced (on order), but spun freely. Bushings look just fine. Has anyone seen this?Replace the anti curl roller just after the fuser , it will be the cause of that problem!
exCSER
08-19-2012, 02:16 AM
I priced the roller....over $100......are you confident that will fix it??
minimerlin
08-19-2012, 11:34 AM
from your description it is hard to give the fix without more details but from my understanding I still think it sounds like the anti curl. You state the problem is when the paper is between the fuser and the pressure rollers. Do you mean the wrinkles are seen only before the fuser or are they visible when the paper has exited the copier? Is the paper damp? I would kook very carefully at the anti curl roller as it becomes very spongey and deformed with age and has to be changed at regular intervals to avoid a fault such as you report. But we can only give advice without seeing the machine in operation.
Darren King
08-19-2012, 02:45 PM
I would also suspect the registration clutch. It is easy to troubleshoot as it is the same as the feed clutches in the paper trays.
Darren
Luther
08-19-2012, 04:05 PM
to make sure its the anti curl roller run face up copies on 14" paper if there is no crease on face up copies and there is on face down then its the anti curl roller, it only uses the anti curl roller on face own copies and duplex copies, very common problem
brent
08-21-2012, 06:30 AM
it might be overkill. b ut... everytime I rebuild one of these fuser units. i replace the fuser roller bearings pic fingers.. and both anti curl roller and the sponge type roller with new one ways (gears with internal bearing) I have had this before. and by doing these all every rebuild it cuts the calls way down. I would do those rollers. but do what luther said first. very good advice
brent
exCSER
08-23-2012, 01:07 AM
Thanks everybody....I've got the roller on order.
Mita-Konica-Tech
08-23-2012, 02:06 AM
brent
I don't think it's overkill completely rebuilding the fuser unit... In fact I would trade 4 of my technicians for just one tech who thinks on his feet like you do... Short term expense vs multiple recalls to complete a Total Call...in the first place...
brent
08-23-2012, 09:40 PM
well thanks! I virtually get no call backs on jamming in that section.
exCSER
09-05-2012, 06:48 PM
Thanks guys!!
I finally got back to the account and replaced the bearings, bushings. and roller. Problem solved!!
Really appreciate the help!!!!
