View Full Version : Server 2008 R2 64 bit support for C5500
emujo
08-27-2012, 07:54 PM
I posted this a few days ago but can't seem to find the post anymore so I apologize for the double posting...
Anyone have a C5500 w/ IC408 successfully printing with 2008 R2 64bit? The driver (ISO File) that KM offers induces an 03xxxxxx error each time I try to load it. It will work if we connect to the print/direct queue, but customer wants uniformity when clients are connecting to the driver and this "looks to different". Thanks for any help. Emujo
dallas
08-27-2012, 08:28 PM
Copied from the EFI Tech Ticker July 2012:
Tech note: Windows 7, 2008 Server R2; Fiery support?
If the Postscript driver for the given Fiery is compatible with 32-bit/64-bit XP/Vista/2003 Server/2008 Server (see the list, below), the same Postscript driver should work fine on Windows 7 and 2008 Server R2. However, EFI has determined that PCL print drivers shipped prior to December 2009 are not compatible.
EFI has released to KM a Windows 7/2008 Server R2 compatible PCL driver for IC-408 v2.0 and IC-412 v1.1
Windows 7/2008 Server R2 compatible utilities including CWS 5.3 have been posted on the EFI website. Standalone CWS 5.3 and Fiery Extended Applications Package (3e) can be found at:
Download Fiery Command Workstation (http://w3.efi.com/Fiery/Products/CWS5/Download) Note: see Tech note above regarding installing these downloadable utilities on Fiery itself (FACI)
Tech note: Post release 32-bit/64-bit XP/Vista/2003 Server/2008 Server print drivers available**
Pi6500e v1.0x: (PS; PPD only) Pi7200e v1.0x: (PS; PPD only)
CN3102e v1.2: (PS; PPD only) CN3102e v2.0: (PS + PCL)
CN3102Pro v2.0: (PS; PPD only) IC-401 v2.0: (PS; PPD only)
IP-921 v1.1: (PS + PCL) IP-901 v1.1: (PS)
IP-901 v2.0: (PS) IC-302 v2.1: (PS)
IC-402 v2.01: (PS + PCL) IC-406 v1.01: (PS + PCL)
IC-405 v2.01: (PS + PCL) IC-408 v2.0*: (PS + PCL)
IC-409 v1.01; on post-release DVD2 (PS + PCL) IC-412 v1.1*: (PS and PCL)
IC-303/305 v2.0*, v2.1*, and v3.0*: (PS only) IC-306 v1.x* and v2.0*: (PS only)
IC-413 v1.0 & v1.1*: (PS Only) IC-3600 v2.0*: (PS Only)
IC-414 v1.0 & v1.1*: (PS Only)
*shipped with product
** Postscript drivers, and PPD-only solutions listed above should work with Windows 7 and 2008 Server R2. But as of this date, PCL drivers for all Fierys listed above are NOT supported for these two Windows operating systems. EFI has released to KM a Windows 7/2008 Server R2 compatible PCL driver for IC-408 v2.0 and IC-412 v1.1 however. These are post releases – not the PCL drivers that shipped with these Fierys.
