View Full Version : Konica 7165 overtoning
Will
12-20-2007, 11:53 PM
Keep overtoning after about 20k and have replaced developer & drum twice; and recalibrated drum percualirty adjustments setsup fine. Replaced toner control board. Checked developer augers, gears, and toner augers can't find anything wrong. Any suggestions Anybody???
random
12-21-2007, 03:36 AM
What is your customer printing? i.e pixel ratio
Will
12-21-2007, 08:03 AM
Just regular line copy nothing out of the ordinary very little in the way of any solids or photo's. They have the Minolta Di650 which is the same as the Konica 7165 and it runs pretty much the same way, and it runs fine.
random
12-21-2007, 10:59 AM
Well that machine does not have a toner density sensor so it gets the available density from doing a patch test on the drum. You will have to go down the route of checking to see if this working correctly I guess. For example is the patch sensor stuffed, toner control board faulty etc. You could compare the outputs in I/O's with the DI.
Make sure the image is exposed correctly in the area where the patch sensor is reading, for example, for some reason there could be a light band in the patch area causing the machine to over compensate and overtone.
From memory I think you can adjust the toner density in the tank and patch density with dip switches.
All I can offer really.
LooksBack
12-21-2007, 07:38 PM
Had a leaky developer unit cause this once. The toner mists out the ends and coats the sensors under the unit and it all goes downhill from there. Didn't notice the developer unit leaked because there was alway toner everywhere.
Good luck!
mitchl
12-21-2007, 08:34 PM
I have numerous DI 650's with the same problem, all in all this is probably the dirtiest running copier ever. I really do dislike this pig and can offer you no fix what so ever other than you can adjust toner drop through the soft switches. I think I remember seeing a thread here giving exact procedure for making this adjustment.
peter lynn
12-23-2007, 05:27 PM
have you changed cleaner blade /collector roller /. grid/charge wires within last 250 k.? are ld1/ld2 set between45 and 50 ?
as you have changed toner c.b. then that cannot be scratched and all along this area is cleaned?much obliged peter
peter lynn
12-23-2007, 05:28 PM
:o
Will
12-27-2007, 12:36 PM
Yes, seems as if overtoning started occuring after 250k PM kit installed and developer change. LD1 and LD2 are both between 45-50.
peter lynn
12-27-2007, 04:34 PM
Yes, seems as if overtoning started occuring after 250k PM kit installed and developer change. LD1 and LD2 are both between 45-50. you did use correct dev as bizhub dev. for 600/750 [dev 710] is different and causes toner problems either way when fitted to wrong model !:rolleyes: much obliged peter
Will
12-27-2007, 11:20 PM
Of course I used the correct developer. I've gone in and cut back the adjustment in 25 mode for toner density and developer density soft switches and will continue to run and see what happens in the next 10-20k copies. Didn't adjust the one for image write density.
bgbas
12-28-2007, 01:57 PM
Try these settings.
7155 - 7272 Background, Toner, Developer Spill Countermeasure Charges7155725571657272Clean optics and drum carriageCharge134134140146Check developer bias bearring install mod if neededTransfer100100100100Modify Developer bias bearing with p/n 090075530 see attatched pictureSep A.C110110130150Set chargesSep D.C105108115125Balance and set LD1 & LD2Grid113114115117Set all drum pecularity adjustmentsTGR0000Set dipsw 23-3 and 27-0 to 1 (Konica recommendation)Dev Bias187184182185Make sure 23-2 is set to 0 to prevent failure codes
bgbas
12-28-2007, 02:02 PM
Oops the previous message did not translate well.
I will see if I can find a compatible file format.
bgbas
12-28-2007, 08:25 PM
PDF attached
peter lynn
12-29-2007, 04:02 PM
just incase i thought i would ask about wrong toner as you mentioned this site had bizhub 600/750 as well as this problem machine .we have several such sites and its unfortunately common for tech's and operators to fit wrong toner/dev.
background/gritty line at front end is sometimes found to be charge grid too close to drum and is best solved by removing the grid cleaning pad completely,and alo cutting the spark arrester shoulders back by1 or 2mm
,this has been done toapprox 80 machines so far with good results
much obliged peter
