View Full Version : Bizhub 7145 (also known as a Konica Minolta 7145)
Milkman
09-03-2012, 01:53 AM
I have a friend that has this printer. I want to do stuff like e-mail from the printer, create PDFs from the printer, or fax from the printer. The printer appears to need some software to communicate with (on a computer), and can't actually do this from the printer itself. I have gone through all of the configurations, and it is all correct.
Does anyone know where I can find this software?
TheOwl
09-04-2012, 07:19 AM
The software that you need is called an 'Email Server'.
To fax, you will need a 'Fax board and phone line'.
JustManuals
09-04-2012, 07:57 PM
And BTW.........The 7145 is NOT a Bizhub machine.
nmfaxman
09-04-2012, 08:10 PM
OPTIONAL....
Type Optional IP-432 Print Controller
PDL Support PCL5e/6
Speed 45 pages-per-minute
Resolution 600 x 600 dpi
Memory 64 MB / 192 MB
Network Card 10/100 BaseT
Print Drivers Windows 95, 98, ME, NT 4.0, 2000, XP
Options 5.0 GB HDD (HD-107) required for downloading
fonts only, Adobe PS 3 Kit (PS-344)
copytechman
09-04-2012, 08:16 PM
Weirdly enough a number mine DO say Bizhub on them. Notably the the 7222-35 series and the 7145 among them! But it tiz a pure Konica regardless.
Regards!
A.
Milkman
09-04-2012, 08:42 PM
Thank you for the reply "TheOwl"
So this printer is completely self sufficient then, and doesn't need any external server software to allow the printer to scan to PDF then??? I assume that I just have the authentication settings wrong then.
The printer looks like it should be able to do all of the functions without external software, but the problems that I had, along with the environment that this printer used to run in, made me believe it required external software.
Also, it is DEFINITELY labeled as a Bizhub printer, but thanks for the clarification.
