View Full Version : Konica minolta bizhub C351 error code C9401
jakespeedme
12-25-2007, 04:36 AM
Hi
I'm working on a konica minolta C351 bizhub with an error code C9401 which came up after I fixed an error code C2255 that turned out to be a jamed iu unit . Is this connected to the first problem ? The exposure lamp was working and now it's not . Any help would be appreciated .
Thank You
alihamed
12-25-2007, 12:31 PM
sir
Troubleshooting
16.6.81 C9401: Exposure Lamp’s failure to turn ON
16.6.82 C9402: Exposure Lamp turning ON at abnormal timing
Relevant Electrical Parts
Scanner Assy
Flat Cable
Image Processing Board (PWB-C)
Step Action
1 Check the flat cable for proper connection and
correct or change as necessary.
2 Change Scanner Assy. — —
3 Change PWB-
jakespeedme
12-26-2007, 11:24 AM
Hi
Thank you for that information . Before I start with those steps I have a further question . Even though the exposure lamp is not turning on shouldn't the lamp bar not do it's little movement cycle indicating it at least has power coming to it .
Thank You
