KM bizhub c203 - sometimes makes the whole piece of background cyan
  • xeroprint
    • Nov 2008
    • 20
    Hello
    I have a problem with KM bizhub C203. Sometimes it happens that normally prints and sometimes makes the whole piece of background cyan (Appendix). Recently background is magenta. What could it be?
    I checked the connections / contacts, and in - everything about
    example : http://xeroprint.net/SKMBT_C25312091110120.pdf
  • ogaliandy
    • Apr 2012
    • 14
    Re: KM bizhub c203 - sometimes makes the whole piece of background cyan
    Hi, I also have the same problem only that mine is producing yellow background and showing p21, am suspecting the contacts of the HV board am yet to resolve mine
    • AjitN
      • Mar 2009
      • 287
      Looks like IU failure or Toner problem.
      • blazebusiness
        SanDiegoCopierRepair.com
        • 1250
        Originally posted by xeroprint
        Hello
        It's probably the printhead unit. To isolate the problem, temporarily block the printhead window corresponding to the color of the background. If the background goes away,replace the P/H Unit assembly.
        • AjitN
          • Mar 2009
          • 287
          If PH unit is defective, there will be backgtound on entire page, in sample we can see the border deletion which is performed by PH
          • Chip Resets SA
            • Sep 2010
            • 46
            Its between the HV and the printhead PH unit - start by replacing the cheaperst option - i have had one of each.
