View Full Version : Bizhub C550 wierd print issue odd shape outlined in white in the center of images
jeremyb503
09-19-2012, 11:35 PM
Anyone have an idea of how I could fix this problem? See the attachment. Thanks!
17291
907tec
09-20-2012, 12:23 AM
Might wanna take a peek at your transfer belt. You haven't been running labels through your machine, have you?
how funny i was just thinking that exact thing as i was looking the img over - aparently you were typing while i was looking
needless to say i concur wtih the labels assement ;)
jeremyb503
09-20-2012, 12:33 AM
I hate to ask (is my ignorance showing again?) but where is the transfer belt located? Is there a place in the manual I should look?
jeremyb503
09-20-2012, 12:35 AM
And by the way, thanks for the quick reply!!
jeremyb503
09-20-2012, 05:51 PM
You guys were totally right. I took look at the transfer assembly and there was a piece of a label or something stuck to it. I peeled it off and there is still some residue so I am wondering what I can use to clean it off the will not damage the belt. Any ideas?
i've used alcohol (90%) and clean cotton with good success - just dont rub too hard and wipe it again with a clean dry cloth afterwards and you should be fine :)
minimerlin
09-20-2012, 08:11 PM
You guys were totally right. I took look at the transfer assembly and there was a piece of a label or something stuck to it. I peeled it off and there is still some residue so I am wondering what I can use to clean it off the will not damage the belt. Any ideas?Glass cleaner, the spray stuff not the cream! Spray onto a cloth made into a pad, get it quite wet then wipe the belt to remove residue let the belt dry and it should be OK.... Or charge user for a belt?
jeremyb503
09-28-2012, 12:46 AM
Thanks for the assist. After a good clean the issues is resolved!
blackcat4866
09-28-2012, 01:05 AM
... and there is still some residue so I am wondering what I can use to clean it off the will not damage the belt. Any ideas?
Get yourself a small bottle of lamp oil (paraffin). It loosens adhesive nicely without damaging transfer belts, drums, guides, rollers, plastics, ... anything. Sure, it's slightly flammable but you shouldn't be smoking anyway. I evaporates quickly leaving no residue. It's miraculous. I used to use Dispersant until it became obsolete. =^..^=
jeremyb503
12-01-2012, 08:46 PM
Well now I've done it. Apparently I did not get all the adhesive off last time and the spot started to come back, so I cleaned it will the paraffin and followed up with glass cleaner. Now when I print the whole image is really dark and on elements with a white background the white background prints Yellow.
What have I done? All I did was clean the belt. I didn't touch anything else. I have tried running several hundred blank sheets just to see if there was some residue that would clean up, but no dice.
Top of the photo shows how it looks now, bottom is what it looked like before.
Help!18462
minimerlin
12-01-2012, 09:28 PM
Have you done the gradation adjust? What is the test print like?
jeremyb503
12-02-2012, 05:21 AM
thanks for the reply.
It seems to be ok now. After waiting a couple of hours I ran a test print and it looks fine. There must have been some residue that needed to evaporate.
How do I do the gradation adjust?
pepper38_cnd
12-03-2012, 01:04 PM
Are we being PUNKED? First the picture that anyone who's been servicing color machines for more than 10 minutes would reconize as a lable on the transfer belt. Followed by where is the Transfer Belt. Now how do I do Gradation? What's next? How do I get into service mode? Even Paul didn't take the bait and offer him a Service Manual!
Avskrap
12-04-2012, 03:16 PM
Seems we've got an end-user on our hands... :)
jeremyb503
12-05-2012, 06:18 PM
I am afraid I am an end user. Is this forum just for techs? I did read the rules and didn't see that. Sorry, thanks for all the help anyway.
pepper38_cnd
12-05-2012, 06:28 PM
Hey Jeremy
you are as welcome here as the next person. I was just making a joke sort for being a smart ass!
Glad you got your problem solved.
jeremyb503
12-05-2012, 06:36 PM
Avskrap
12-06-2012, 08:05 AM
No grief intended with the end-user comment, it's just that 99% of us on here are techs, we write and think as such. End-user level help and advice are found in the user manuals, whereas here we talk dip switches, NVRAM swaps and fuser rebuilds. A whole other level, and it's not particularly useful from an end-users point of view.
