View Full Version : Error Code code 2152 c 360
mbhana
09-20-2012, 07:36 AM
tried a new pwb board . but erroe code comes back after a day.
pls can some one help.;);):D
Darren King
09-20-2012, 01:35 PM
Products:
bizhub C360
bizhub C280
bizhub C220
Options:
None Specified
Details
Subject:
Various error codes, such as C2152, C2253, C3201 and C5102 may be indicated as the MFP begins to run through stabilization. All the errors are drive motor related.
Description:
Various error codes shortly after power up.
Solution:
CAUSE: The MFP power supply is failing.
SOLUTION: Replace the power supply (p/n A0ED M400 03).
mbhana
09-20-2012, 01:44 PM
Products:
bizhub C360
bizhub C280
bizhub C220
Options:
None Specified
Details
Subject:
Description:
Solution:
thanks i will try it and see what happens and let u guys know if that helps.
EarthKmTech
09-20-2012, 09:39 PM
Does this code have the same meaning as per the old machines, ie, transfer belt internal colour transfer rollers retraction malfunction? (dont have my manual on me at the moment)
If so, the transfer belt itself would of been the first logical step ;)
JustManuals
09-21-2012, 12:53 AM
Paul@justmanuals.com
styaner
09-21-2012, 05:46 AM
C2152
transfer belt pressure welding alienation
part # A0EDM40003 for power supply
Have not seen this yet but we will as the machines age
habik
09-21-2012, 06:14 PM
That is exactly where I would have started with ITB, check manually if it is easy to engage or disengage the 3 color 1st transfer rollers. Maybe one of them is hanging. Never had it so just guessing :)
