Bizhub 282 hangs
  • bashboosh
    • Dec 2011
    • 24
    Bizhub 282 hangs
    Hi, i appreciate any help on my bizhub 282 mfp.
    This printer often hangs and doesnot print. during this time, copier functions are ok. I even tried connecting directly to a USB but same result. I tried changing drivers and no luck. The technician told it can be some corrupted print job is being sent to the printer. How we can troubleshoot this issue?
  • Avskrap
    Partner in crime
    • Jul 2011
    • 160
    Re: Bizhub 282 hangs
    Talk to your technician, tell him to upgrade the FW. He should know that this is something you always do as a first step when dealing with these kinds of problems.
    • bashboosh
      • Dec 2011
      • 24
      Thanks for the reply. How do i know which version FW is installed now? is the FW publicly available? The support opportunity is very less in my area and thinking if i can do it.
      Thanks again.
      • Avskrap
        Partner in crime
        • Jul 2011
        • 160
        FW is not publicly available and for technician use only. You need to be a certified technician to get hold of it. The current FW installed in the machine is stated in the service mode (something your tech also should know how to look up).
        • bashboosh
          • Dec 2011
          • 24
          No problem. Thank you for the replies. I will look around to find who can do it.
          • bashboosh
            • Dec 2011
            • 24
            Yesterday the technician did the firmware update to latest. Did not face any problem for 2~3 hours. After that the original issue started again. The printer loses the network connectivity. After exactly 15 ping time outs, it get back to network.
            Dont know where is the issue. Today i will try to install a computer in this network outlet and check if there is any network issue occur.
            Are there any other experiments to get relove this? Thank you experts.
