View Full Version : c250 stabilizer ng why?
mrfuser
09-25-2012, 06:11 PM
Can not get this to.do gradations. No error shows up but in service mode it says stabilizer ng.
Any ideas why?
Kelly
907tec
09-25-2012, 06:14 PM
Are you sure there aren't any P-codes? Every time I see the "NG" message, there has been a related P-Code. Did you check under "warnings" when you were checking the service codes?
Darren King
09-25-2012, 06:17 PM
907tec is right. Check for an oilcan on the screen. If it is there, touch it and it will show the P codes.
EarthKmTech
09-25-2012, 09:54 PM
I've had this before with no error codes on a few machines.
If someone tries to print to the machine when its in service mode this can happen. restarting the machine from the main switch and disconnected from the network usually solves the problem for me.
However, as above check for P-codes first.
kingarthur
10-01-2012, 12:29 PM
have had this on C352 & C250...go into tech rep mode & increase the "scan area"
