NEED HELP
  • RONHEIM
    NEED HELP
    HAVE PANAFAX UF 300 HOW DO I TURN OFF INK OUT CODE
    015 ??
  • ray
    Re:NEED HELP
    put in a new ink cartridge. if you did and still get message, you may have a faulty cartridge. especially if using generic. try another cartridge and cleaning your gold colored contacts on your print carriage behind your cartridge. if this doesn\'t do it, it will need to be serviced.
    good luck,
    ray
    • imagertech
      • Apr 2005
      • 41
      Re:NEED HELP
      function 7 tel/dial 4 times * test mode 1 start, function parameter 63 is ink test.
      • dqydj
        • Jun 2005
        • 65
        Re:NEED HELP
        If you open the printer cover and move the printer carriage
        to the left you can see the rubber pad where the cartridge rests & the little rubber blade the cleans the tip of the print cartridge.
        just to the left of the pad is a opening. at the bottom of the opening
        is the out of ink sensor. usually there is a build up of dried ink
        blocking the sensor.
        you can GENTLY remove the ink with a cotton swab that is
        wet (only water).
        this might take a few swabs. if the build-up is extreme you
        might get a big chunk that snaps off. try to remove it if possible.
        the ink is water soluable so only use water.
        hope this helps.
        Post edited by: dqydj, at: 2005/09/12 10:08
